Re: WD 6 diesel leak into injector pump crankcase
Posted by Ron in Nebr on December 13, 2003 at 18:45:50 from (65.165.16.27):
In Reply to: WD 6 diesel leak into injector pump crankcase posted by Mark on December 13, 2003 at 10:14:56:
When you took your pump in to be overhauled, did you take the scavenge pump in too? My 650D I just bought does the same thing, and from reading through the archives here it appears there's a seal in the scavenge pump that goes bad and lets fuel into the injector pump's oil supply. Supposedly it's a pretty common problem on the IH gas-start deisels.
The manual says you're only supposed to have to change oil in the injector pump when you change engine oil.
Post A Followup
: Re: Re: WD 6 diesel leak into injector pump crankcase
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
