Re: Re: Re: Farmall H timing with a distributor
Posted by Steve - IN on December 14, 2003 at 17:35:30 from (12.222.30.13):
In Reply to: Re: Re: Farmall H timing with a distributor posted by Mark on December 14, 2003 at 16:20:41:
Mark, You should find a TDC, a static timing mark, and a max timing mark on the pulley. The static and the TDC mark should be fairly close together, and the max timing should be 30 or 35 degrees from TDC (memory fails, my service manual is out in the barn, and it's COLD!). If you're starting from having pulled the distributor, turn the engine to the TDC or static timing mark -- they should only be 4 or 5 degrees apart -- pull the #1 plug (farthest front) ground it to the tractor and move the distributor until you see the plug spark. That should get it timed well enough to start it. If your H is still + ground or 6 volts or both, you're going to need an external 12v battery to use with your standard automotive strobe timing light. The other hassle is that with a 50+ year old distributor there's going to be enough slop that you can see your dynamic timing jumping a few degrees either way while you're using the strobe. If it is steady, crank in 3/4 to 80% throttle and move the distributor until the light fires showing the pointer lined up with the max mark. If you don't want to go the spare battery / trust the distrubtor route - set the throttle at 20% - 40% and move the distributor until you hear the fastest idle speed, then back it off and tad, bolt down the distributor then take it out and try the engine under load, listening for pre-igntion. If it sounds good, you've gotten 95% of the result for half the effort. If you hear a ping, retard it a little - and generally err on the side of too much retard to be safe. Anyway, either way, it shouldn't take you long to get the old H purring like a kitten - which is the real payoff. Good luck, and have fun with it.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
