Super C won't fire
Posted by Joshua on December 15, 2003 at 13:22:38 from (216.104.132.210):
Hi,
Somebody out there that can help me?
I have a Farmall Super C.I rebuilt
the whole firing system.So I've
got lots of spark.How do you know
which wire on the dis-cap goes
to which cylinder on the block.I
know the firing is 1342,but does
1342 start back buy the gas tank
or up by radiator.I even sprayed
starting fluid in the cylinders
would not fire.Readusted the valves.
Thanks for the help.
Post A Followup
: Re: Super C won't fire
