Re: Super C won't fire
Posted by Ken in Iowa on December 15, 2003 at 20:18:01 from (12.64.48.148):
In Reply to: Super C won't fire posted by Joshua on December 15, 2003 at 13:22:38:
Joshua: When the number 1 piston (front) is on top-dead-center on the compression stroke, remove the distributor cap and the rotor should point to the terminal that leads to number 1 cyl. If not the dist. may be installed wrong or you may not have it on the comp. stroke. The best way to find the comp. stroke is to remove the #1 plug and put your finger in the hole while a friend handcranks the engine or with the valve cover removed just follow the 4 cycle action. After you get the number 1 in the right position, install the other wires following the firing order. After it starts, use a timing light. Good Luck, Ken
Post A Followup
: Re: Re: Super C won't fire
