Re: cub rear seal
Posted by Dale on December 15, 2003 at 19:46:46 from (12.76.238.15):
In Reply to: cub rear seal posted by mike on December 15, 2003 at 12:40:55:
I have seen some that people used a lot of sealer on and they still fail after a few years.About 8 years ago I fixed one by cutting a piece of .001 shim stock to wrap around the seal,now I have done 3-4 like this and never had one come back leaking some will take .002 to get a tight fit.If you do this make sure that the seam in the shim stock is on the top side.
Post A Followup
: Re: Re: cub rear seal
