Re: Re: HELP!! What is it????????
Posted by Buzzman72 on December 16, 2003 at 06:30:54 from (207.69.140.35):
In Reply to: Re: HELP!! What is it???????? posted by ChadS on December 15, 2003 at 19:30:36:
I think your truck guy is shooting in the dark...mainly because the L-series trucks were 1950 to 1952 models (some leftover '52's were sold & titled as '53's in some locations). So let's look at this logically. If it's from an L-series, that would be '50 to '52...but that number doesn't come up in my parts books for the SD-220/SD-240 used in most L-series thru 170. It might be from an RD-series, but since those were larger sixes, I don't think that's likely. My best guess would be a BD-series engine. My Glenn Mitchell Interchange Manual shows the '57-'59 BD-220 to use a 164415-R head, and the '60-'63 BD-240/BG-241 to use a 164415-R head. And walking outside to examine my '51 and '52 L-110 pickups didn't reveal any external casting numbers...but it did bring something else to mind. The stock SD-220 engine in the '51 uses a narrower valve cover, as it's what is referred to as a "non-tilt valve" engine...while the BD-264 that somebody transplanted into the '52 uses a wider and taller bvlave cover, and IS what they call a "tilt-valve" engine. So the "tilt-valve" vs. "non-tilt valve" heads might also affect piston clearance; that is, if your pistons are set up for a tilt-valve head, a non-tilt valve head might have some piston-to valve interference. I know this probably confuses the issue some, but from what I'm discovering--since I don't have a '53-up truck parts manual--is that you've probably got a BD-220 or BD-240 head, of the non-tilt valve variety. BTW, my parts book shows the SD-220/240 head part number to be 76980-R92 (with valves) and 76979-R91 (with guides only). Hope this is more help than hindrance!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
