Re: Thermosyphon and recored rad?
Posted by Farmalldan on December 17, 2003 at 11:36:55 from (64.154.26.251):
In Reply to: Thermosyphon and recored rad? posted by SAm in NS on December 17, 2003 at 08:04:47:
Sam, If your tractor overheats in service, it will blow steam from the overflow, etc. If this is a new experience for you, you will think it is on fire, but it isn't. If it happens, allow it to continue running at a fast idle with no load. Carefully remove the radiator cap. If you have a pressurized system, be VERY careful. When the pressure is removed, much of the water will flash to steam. It is sometimes better to cool down pressure systems by a water spray on the radiator or shutting the engine off to avoid the hazards of steam burns. For a non-pressure system, remove the cap and slowly add water until the radiator is at the proper level again. Add slowly so that cold water does not enter the block and crack it. The thermosyphon systems could have an optional temperature gauge which connected to the lower water inlet. Not the best place, but that was where it went. The gauge fit in a bracket that attached to the governor housing. Tractors with added water pumps should also have the upper water outlet replaced with the outlet for a thermostat. Operating without a thermostat does not allow proper warm-up and is very hard on engines. The thermostat outlet has a gauge connection in it, which is the preferred location. Pressurized cooling systems do not cool any better than non-pressure systems. They merely allow the water to reach a higher temperature without boiling. A water pump will work with pressure and nonpressure systems equally well. Before you condemn your new radiator and spend some more money, determine whether it will cool your tractor. If you can operate your tractor regularly without continuous loss of coolant, it is adequate. I would certainly think it would be ok in the winter. Remember that loose fan belts, retarded timing, and lean mixtures make engines run hotter.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
