Farmall Tractors Discussion Board
Re: Farmal M front wheel bearings etc.
Posted by Bob M on October 06, 1999 at 18:05:06 from (205.188.199.179):
In Reply to: Farmal M front wheel bearings etc. posted by Rod Hergott on October 05, 1999 at 20:52:36:
Rod - ltf and Phil's advice is right on. But let me add a couple more tips: 1 - Thoroughly clean all the old grease, etc.from inside of hub bore - it will let you better see the exposed edge of the cup race. 2 - Set the hub with it's outer end down on a substantial metal surface (a large anvil is ideal...) and use a short, heavy punch and large hammer. Work the punch gradually around the circumference of the cup race, a dozen or so whacks per revolution. The cup race will eventually work free.
And wear safety glasses! The cup race is hard as a banker's heart, but if a piece gets chipped off and goes in your eye, it'll blind you.
Good luck!
Post a Followup
: Re: Re: Farmal M front wheel bearings etc.
