Farmall Tractors Discussion Board
Farmal M front wheel bearings etc.
Posted by Rod Hergott on October 05, 1999 at 20:52:36 from (207.34.100.227):
I need help. I presume that the front wheel assembly looks like this on a Farmall M tricycle row crop.
1. Outside dust cover
2. Outside bearing.
3. cup (race) the thing that the bearing sets in.
4. The hub.
5. The inside cup (race)
6. The inside bearing
7. A dust seal.
My M doesnt have 7 the dust seal and I'm having a hard time figuring out if it has an outside cup (3). I think it has been fused to the hub cause I can't get it out. I'm planning to take it to a machine shop to have it removed.
Have I described the assembly correctly? Does anybody know any of the bearing and cup timken part numbers?
Thanks.
Post a Followup
: Re: Farmal M front wheel bearings etc.
