Re: Re: Re: Re: Farmall C Rear wheel issue!
Posted by Tommy H on December 17, 2003 at 19:18:45 from (65.140.18.42):
In Reply to: Re: Re: Re: Farmall C Rear wheel issue! posted by Nebraska Cowman on December 17, 2003 at 18:25:23:
See, thats the thing, about a quarter size ($.25) around the valve stem is badly rusted to the point the stem moves. It is tubed and has a very slow leak. Im going to restore it the right way, but im not going to go out and buy a new rim if the original can be fixed.
Ill tell ya! Theres alot more wrong with this thing than Ithought! Im starting to wonder if its worth it.
Major stuff thus far without having removed anything: Intake/exhaust is cracked and missing chunks, Front rims are shot (adjustable kind), the seat is completely trash.Electrical is about as shoddy jerry rigged as it gets. Im not backing out, but daggum! Ill start tommorow and remove the battery, and wheel weights.
Post A Followup
: Re: Re: Re: Re: Re: Farmall C Rear wheel issue!
