Re: Re: Re: Re: to rebuilder smta ta
Posted by paul on December 21, 2003 at 05:57:15 from (216.114.4.162):
In Reply to: Re: Re: Re: to rebuilder smta ta posted by Chuck's Repair on December 20, 2003 at 19:16:46:
Chuck's repair. I hace been in auto service for years and wonder why you cannot use dextron to replace hy-trans we have been using dextron for years in manual transmissions to ease shifting effort and grinding.when i am done with repairs this tractor will be used for antique tractor pulling stock.no long hard work under load.i have also heard that hy-trans will cause seals to leak will dextron do the same?? Paul.
Post A Followup
: Re: Re: Re: Re: Re: to rebuilder smta ta
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
