Re: Hey pcy==,rear oil seal tool question
Posted by p-c-y on December 21, 2003 at 06:53:36 from (199.35.245.142):
In Reply to: Hey pcy==,rear oil seal tool question posted by Vern on December 20, 2003 at 19:03:56:
we are not set up for pictures , its real simple , just a flat pieasa steal with four of the flywheel bolts holes drilled in it, it is like 8 inch by 8 inch 1/2 inch thick, 3/8 would work fine, take the flat piece put the seal flat against it put the 4 bolts in the crank , pull them up flush, back them off put the plastic ring that comes with the seal on the seal and tighten the bolts again, the plastic ring will pushthe seal to the correct depth, real simple and cheap,works great
Post A Followup
: Re: Re: Hey pcy==,rear oil seal tool question
