H rear axel housing gaskets
Posted by Gary V on December 22, 2003 at 14:31:54 from (4.72.100.24):
Need to replace axle housing gasket on h model. I think thats what you would call it.It is the housing that goes over the rear axel that bolts to the rearend. My question is . How do I replace these. After taking the wheel and the outer axle bearing seal off can I just unbolt the axel housing from the rearend and slide it back enough to put a bead of sealer around it. Or is there more to it than that. Thanks and Have a merry and SAFE Holiday.
Post A Followup
: Re: H rear axel housing gaskets
