Re: H rear axel housing gaskets
Posted by NDS on December 22, 2003 at 18:57:25 from (152.163.252.227):
In Reply to: H rear axel housing gaskets posted by Gary V on December 22, 2003 at 14:31:54:
I agree with others on safety did not elaborate on that but we had had tractors blocked up hundreds of times and knew how to do it safely. One more word of warning never use concrete blocks they can break without warning with disastrous results we always used 8X8 or larger hardwood blocking. On removing wheels we never tried to remove them in one piece remove tire and wheel if they are not loaded can handle them by hand OK, remove weights if any about 140 lbs.each then remove wheel this might take a little longer but in my opinion it is a lot safer.
Post A Followup
: Re: Re: H rear axel housing gaskets
