Re: Re: Re: Re: Re: possible electrical problems?
Posted by Hugh MacKay on December 23, 2003 at 05:35:25 from (216.208.58.192):
In Reply to: Re: Re: Re: Re: possible electrical problems? posted by Diana on December 23, 2003 at 05:00:28:
Diana: Don't let the difference between glow plugs and manifold heater throw you off. While they are different systems they both rely on heat and that heat creates a big demand on batteries. That demand may not be exactly same but in cold weather the bottom line is you must have enough reserve for the heat demand plus cranking. I realize the Utility type tractors do not allow same room for batteries as do Farmalls. We used to put on Farmalls, batteries just ahead of clutch pedal and on other side just ahead of brake pedals. You could put batteries in there one could hardly lift.
Post A Followup
: Re: Re: Re: Re: Re: Re: possible electrical problems?
