C60 Oil Pressure Problems
Posted by Wilson on December 25, 2003 at 17:49:28 from (216.214.86.116):
I had my C60 engine rebuilt (new bearings, pistons, etc.) and am trying to get in running again. My problem is no oil pressure. With the engine cranking oil just trickles out the hole in the side of the filter cavity. I started the engine, no change. I took apart the the pressure valve below the distributor and just found assembly lube, and no sign of oil. I took apart the oil pump, and yes, the pump drive gear key was properly installed to the camshaft. Repacking the pump with assembly lube didn't help. Is there a galley plug somewhere that my rebuilder might have forgot to install?
Post A Followup
: Re: C60 Oil Pressure Problems
