Re: 1967 INTERNATIONAN HYDRAULIC PROBLEM
Posted by Jimmy King on December 26, 2003 at 08:09:10 from (63.189.9.52):
In Reply to: 1967 INTERNATIONAN HYDRAULIC PROBLEM posted by KEN on December 26, 2003 at 07:44:53:
That would be a 706 I would think The first thing you need to find out is how much pressure you have at the remotes should be at least 1500 PSI. If you don't you have two possibilitys the pump is bad or the relief valve is bad. You said the oil in it was milky looking, water in oil or 90wt gear grease ???. could be someone put 90wt in for more pressure??
Post A Followup
: Re: Re: 1967 INTERNATIONAN HYDRAULIC PROBLEM
