Re: Carburetor Float Question
Posted by rebuilder on December 26, 2003 at 16:27:12 from (66.228.102.71):
In Reply to: Carburetor Float Question posted by Kevin on December 26, 2003 at 15:28:05:
Kevin: These are the most common problems with floats on carburetors I rebuild. 1) The float has fallen apart either from excess vibration or excess heat melting the solder. 2)the float does not "float" due to a pinholeleak or a crack in the solder. Shake the float itself and you will feel gas moving inside the float. I have tried to drain and resolder floats with no luck and besides you can generally buy a new float fairly cheap. 3) I have found the float tends to "stick" along the sides of the carb. Fisrt thing you need to do and the last thing you do after a rebuild is to twist the carb. in your hands. You should hear or feel the float moving. If not take apart and CAREFULLY bend one or the other sides to adjust the fit, then assemble & twist again. 4) many older carbs. will be rusty or sticky enough from varnish to cause the float to stick on the pivot axle. Make sure float & needle valve combo move freely. 5) if after rebuilding the carb you still have gas leaking out, many times this can be fixed by bending the float down slightly so it will shut the fuel off sooner. 6) make sure you have the pivot bracket sides close but not tight against the float and that the axle "IS" tight by clamping with the split end of the pivot bracket.(I found out the hard way by having a 300 carb that I rebuilt cause a gas fire. Luckily the fire was put out without too much damage and the tractor in question just happened to be owned by a relative"WHEW". Near as I can tell on the carb I rebuilt I did not get the float axle clamped tightly enough as well as the pivot bracket sides were to far apart. Vibration etc. caused the float axle to slide out and the float "fell" cockeyed into the bowl which in turn cused the fuel to gush out hitting a hot motor and starting the fire. Thank god it was put out quickly, but I had some serious questions about my ability thrown my way. I guess that is one way to learn!! If you have any more questions thow a post my way. Merry Christmas & happy New Year.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
