Farmall Tractors Discussion Board
Re: H hyd pump
Posted by Mike H on October 07, 1999 at 20:41:54 from (206.181.23.74):
In Reply to: H hyd pump posted by Rob on October 07, 1999 at 20:05:16:
Hyd. pumps are very simple on these IH models I am JD fan but work on them all the pump comes out the bottom with a floor jack easily there is a small cover to take off then the control lever and unscrew 3 pipe fittings 2 on left and 1 on right from both sides and filler cap.There is a drive coupling with 2 cotter keyes to remove and 4 3/8 bolts P.S. these pump systems leave alot to be desired they are power up only, unless you use a log splitter valve. If you need more info HOLLER!
Post a Followup
: Re: Re: H hyd pump
