Re: Re: Re: 12V Ignition troubles
Posted by Bob on December 26, 2003 at 22:46:58 from (66.163.134.177):
In Reply to: Re: Re: 12V Ignition troubles posted by Jason Again on December 26, 2003 at 18:46:43:
If the coil states "Use with external resistor" it definitely needs to have a resistor used with it to reduce current draw through the points to a manageable amperage when used with a 12 volt system. As far as your other tractor, you may have just been lucky, or have not put enough hours on it to burn the points. The make of the actual distributor should not matter. One other possibility is that the person converting it to 12 volts used a length of resistance wire in the harness from the ignition switch to the coil. Some cars and trucks in the late 50's up into the 70's used the length of resistance wire to serve the same function as a separate ballast resistor. With your NAPA coil, you will need a ballast resistor. There are two types. One type is a fixed resistance of somewhere around 1.5 ohms. This ballast resistor is designed to be used with a start bypass circuit from the starter solenoid "R" terminal to the coil side of the ballast resistor to improve spark voltage available for starting. The other type of ballast resistor has a positive temperature coefficient, so it will have about .60 ohms resistance when cold, as in when you first turn the ignition switch on to crank the tractor, and the resistance will rise to about 1.5 ohms, or so after the tractor has been running for a minute or two. This second type of ballast resistor gives good spark voltage for starting, but, yet, the resistance rises soon after starting to allow good point life. No starting bypass circuit is needed with this second type of ballast resistor. A knowlegeable parts counterman should be able to find the resistor(s) that are listed as compatable with your particular coil. I generally use Standard Ignition (brand name) parts, and their catalog lists the proper resistors to use with their universal coils, and I'm sure NAPA would do the same.
Home
| Forums
Today's Featured Article -
The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
