Re: SMD thrust bearing
Posted by 49 Cubber! on December 27, 2003 at 18:05:56 from (206.74.216.142):
In Reply to: SMD thrust bearing posted by 49 Cubber! on December 27, 2003 at 13:11:14:
Heres some pics of the lower thrust bearing.the captions will explain,to the best of my ability,the problems with this bearing.The other main caps I have pulled have some wear on them but not like this one and I wonder if it was not replaced and the others were.The rod bearings I have been able to get out looked normal,no major scarring ot scrathing,just wear.
Post A Followup
: Re: Re: SMD thrust bearing
