Thanks re What am I missing! from happy 300u owner
Posted by Jerry on December 28, 2003 at 05:51:37 from (67.73.163.5):
Thanks all who helped back on the 18th. I have been fighting with my 300 for over a year in my spare time and have been unable to get it running. The original problem was that it ran fine for about 5 minutes, then shut down.
After new cap rotor coil wires timing carb rebuild, someone suggested taking off the gas tank. Sure enough, the sediment bowl was full, but the little hole with the splash block had a nice piece of wood in it and there was more in the tank waiting to replace it. The carb would drip fill when the tractor was off, then dry up when used. I also found the wire from the switch to the coil was bad. (How do these get bad?)
Anyhow, I am 99% ready to go for snow plowing and thank God that the weather has cooperated to let me work instead of fret this last week.
Thanks again,
Jerry
Post A Followup
: Re: Thanks re What am I missing! from happy 300u owner
