Re: Re: 656 hydro transmission problem
Posted by ed on December 28, 2003 at 07:17:01 from (172.209.124.55):
In Reply to: Re: 656 hydro transmission problem posted by Chuck's Repair on December 27, 2003 at 19:13:41:
It sounds like what you described about the shuttle valve. This only seems to happen when the lever is in the forward position. When you slide the lever forward the tractor moves forward for a couple of seconds then stops, if I pull the lever back towards neutral just a small amount it will move forward and then do it all over again. The reverse seems to work okay. Can I get to the valve easily or is it a problem? Im gonna get a book this week if possible. Thanks for the help!
Post A Followup
: Re: Re: Re: 656 hydro transmission problem
