Re: 656 hydro transmission problem
Posted by Chuck's Repair on December 27, 2003 at 19:13:41 from (216.170.58.10):
In Reply to: 656 hydro transmission problem posted by Ed on December 27, 2003 at 09:46:19:
Since this happened all at once could you have happened to kick something up against the foot and inch petal to hold it away from the deck.That petal has to be completly back to bild drive pressure.The shuttle valve may also be sticking in the bore.It has to move freely.When it does move does it jump like it wants to raise the front end off the ground? That would indicate going in and out of neutral which should only happen at the crossover between zero forward and zero reverse.To test that try moving the selector handle sideways towards the neutral position while you are traveling forward.
Post A Followup
: Re: Re: 656 hydro transmission problem
