Re: Re: Re: IH injection pump expert
Posted by Chuck's Repair on December 28, 2003 at 08:44:31 from (216.170.58.10):
In Reply to: Re: Re: IH injection pump expert posted by chuck on December 28, 2003 at 07:21:45:
After checking the service manual and rereading your first post where you stated that the exhaust temperatures were different on each stack I believe what you are experiencing is unequal fuel delivery between the two plungers rather than a timing problem.There is test equipment that is necesary to check this,since it is a little confusing I would rather you called me if you still are planing on working on this pump.I won't be home today but call me tomorrow at 308-382-6651
Post A Followup
: Re: Re: Re: Re: IH injection pump expert
