Re: farmall H clutch problems?
Posted by Michael Soldan on December 29, 2003 at 16:04:38 from (216.46.130.23):
In Reply to: farmall H clutch problems? posted by RayA on December 29, 2003 at 11:51:59:
Ray, is it 5th gear it pops out of or all gears? H's are notorious for jumping out of 5th, when the shifter gets worn a bit. My experience with H's is that owners often did not follow the maintenance plan very well. The fingers on the clutch need to be adjusted so they are even with each other and there is about 2-5/32th inch clearance. If you don't have a belly pump it is easy to get at them through the belly pan and they adjust easily. Loosen the jam and turn the bolt until the finger is in the desired position, getting them the same is important. That should give you the release to shift the lever and get the tractor all the way in gear. There could be other problems with the clutch but start there. If you have a belly pump it is more work to remove it but you need to look up in there and see if there is room to adjust those fingers. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
