Re: Reverse Engineering, 424 Hydraulics
Posted by pat on December 30, 2003 at 10:13:43 from (216.238.59.212):
In Reply to: Reverse Engineering, 424 Hydraulics posted by BlueLite on December 30, 2003 at 09:39:07:
I would like to here if it works because that sounds like what I am going thru with my 444 I think it is virtually the same tractor, I have hydro back to the remotes but nothing on the 3 point arms, I had this apart and read and reread books and it seems there are a pot of pumps and O rings that operate this system, so now the tractor sits, but I will look forward to hearing if your idea works, good luck,pat
Post A Followup
: Re: Re: Reverse Engineering, 424 Hydraulics
