Re: Knock in F-30 engine
Posted by okla/kans Bill on December 31, 2003 at 13:47:19 from (209.240.205.63):
In Reply to: Knock in F-30 engine posted by okla/kans Bill on December 28, 2003 at 11:46:06:
I see now that if I take the rods loose, none should have any give in them but the one loose in the piston. If I order a used rod and piston, how much trouble will I have with them not possibly fitting the same on the crank? Also, how much trouble will I have slippg the piston up the bore from the bottom. What is your thoughts aout getting a piston and rod, cutting it off 1/2 way down or so and welding it to the bottom half of the arm I have, so as to keep the fit that is already there? Thanks for all the help guys.
Post A Followup
: Re: Re: Knock in F-30 engine
