Re: Can you increase amps from generator on a WR9
Posted by Bob M on December 31, 2003 at 15:01:48 from (66.66.126.128):
In Reply to: Can you increase amps from generator on a WR9 posted by RAR/IA on December 31, 2003 at 14:44:08:
Roger - The generator's max output can be changed by repositioning the "3rd brush" in the generator. The adjustment is easily made with the generator on the tractor: Remove the generator dust band and look inside for the 3rd brush. It will be the brush that doesn't have a mate exactly 180 deg opposite on the commutator. Now look for a long, slotted head screw on the outside end of the generator near the 3rd brush. Loosen the screw a couple turns - this will unclamp the 3rd brush holder. Next carefully rotate the brush holder CLOSER to the nearest fixed brush, but leave 3 commutator bars showing between the two brushes. Finally tighten the clamp screw and you are done. Your generator will now be set at maximum output and should deliver somewhere between 12 and 16 amps at full RPM.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
