Re: IH 354 clutch problems
Posted by IT WORKED!!! on December 31, 2003 at 15:21:36 from (209.153.128.136):
In Reply to: IH 354 clutch problems posted by Ronofohio on December 30, 2003 at 11:11:55:
Took my 354 out today after warming it up real good. I started it in grear and then drove around the field with my foot on the clutch pedal while alternately applying opposite brakes. I parked it for another ten minutes while letting it run, and then pushed the clutch in and felt alittle pop when the disk finally released from the flywheel. I believe that it has been rusted on for almost a year. Seems great now. I suggest that you give this a try before you split the tractor for a clutch job.
Post A Followup
: Re: Re: IH 354 clutch problems
