656 Hydro will not more forward or reverse.
Posted by Mark on December 31, 2003 at 17:36:23 from (63.159.193.227):
Im working on a 656 hydro. I checked the charge psi under 4 bolt plate on top. 425 psi I also checked the servo psi 180 to 200 at the multi valve. I removed the check valves and inspect them for sticking. all are free. now what. I ordered a 10k gauge to test the run psi. It does not make any hydrolic noise at all. can you Help. thanks
Post A Followup
: Re: 656 Hydro will not more forward or reverse.
