Re: 656 Hydro will not more forward or reverse.
Posted by Gary on January 01, 2004 at 06:18:55 from (66.226.101.74):
In Reply to: 656 Hydro will not more forward or reverse. posted by Mark on December 31, 2003 at 17:36:23:
Firt thing you are reversed on the charge and servo test ports. Servo test port is under the plate and charge pressure is on the multi valve but the pressures are fine. You said you took the check valves out. If you are talking about the ones inside the center section they don't cause much trouble and they will only keep it from moving in one direction depends on if is the forward or reverse check valve. Remove the two lines coming out of the side of the hydro housing. Put caps on the two fittings don't worry about capping the lines and try to move the tractor becareful the tractor will not stop when you push the pedal you have to stop it with the lever. If it moves the problem is in the drive control valve or foot-inch valve. If it doesn't move the trouble is inside the hydro. Possible relief valve stuck open.Either valve will keep it from moving. Email me if you want more detailed info
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
