Re: IH 354 clutch problems
Posted by fergfarm on December 31, 2003 at 21:46:04 from (24.197.0.6):
In Reply to: IH 354 clutch problems posted by Ronofohio on December 30, 2003 at 11:11:55:
GG is right. remove the access cover and if all the fingers are in place the disc may be stuck. I have had this happen several times.
Block the pedal down or have someone hold it.
take a thin blade screw driver and go between the disc and flywheel to release the disc.
On a recessed flywheel you may have to turn it around to find a hole to get to the edge of the disc.
Drilled a hole in the bell houseing on a yammar once to get one unstuck because they don,t have a access.
Post A Followup
: Re: Re: IH 354 clutch problems
