Farmall 560 gas question- aftermarket coil and IH
Posted by skip on December 31, 2003 at 22:08:14 from (152.163.252.227):
Help needed again...
!. I bought a Carquest "hot" coil part #EC UC-12x,cost $50.19 and resistor # RBR 24036 cost$12.82
Also bought champion spark plugs #502 (D21) and universal wire set, points, condenser, rotor and cap.
The auto store says its a replacement hotter version from stock but coil is almost twice the size. Question is, do I buy a bigger bracket and use it or go to the Case/IH dealer and get stock coil.
2. Bought an air filter from Case dealer and it appears that it is too long. Part #AF808K.
I know I'm going to appear really dumb, but I cant seem to get the old air filter out to measure the two. I unscrewed the circular clamp, dropped the bottom and inner metal part that holds the oil bath. Cant seem to get the filter out. I'm waiting for the service and parts manual to come I ordered from Binder Books, but until then, I'm stumped and dont want to pry anything I'm not sopossed to. Would appreciate any advice on either subject. Thanks
Post A Followup
: Re: Farmall 560 gas question- aftermarket coil and IH
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
