Re: Farmall 560 gas question- aftermarket coil and
Posted by E J on January 01, 2004 at 09:25:11 from (67.31.155.116):
In Reply to: Farmall 560 gas question- aftermarket coil and IH posted by skip on December 31, 2003 at 22:08:14:
Take it out & use a pressure washer on it then blow it out replace with new oil.
Post A Followup
: Re: Re: Farmall 560 gas question- aftermarket coil and
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
