Re: all this talk of 444's,,I had to go look
Posted by Blue Lite on January 01, 2004 at 08:22:55 from (216.209.139.62):
In Reply to: all this talk of 444's,,I had to go look posted by pat,maplehillfrm on December 31, 2003 at 17:18:26:
Manual says:
Won't lift in either position or draft:
1/ System overloaded (sound like yours is OK).
2/ Pump drive failed (no you)
3/ Regulator piston stuck in open
4/ Relief valve spring broken
5/ Isolating valve closed (not you)
Will not lift on one control:
Faulty control linkage
Plunger binding (position control)
Post A Followup
: Re: Re: all this talk of 444's,,I had to go look
