Re: Super A Transmission
Posted by Dave on January 01, 2004 at 15:12:18 from (24.33.236.29):
In Reply to: Super A Transmission posted by Charles Ryall on January 01, 2004 at 10:33:26:
Charles, the new seals are about 1/3 as thick as the original seal. The original seal that I removed out of mine was about 1 18" thick. I used three of the new ones to replace the original. These are CR seals (Chicago Rawhide) IH part #48114 D The CR part # is CR 13865, which should be available at your local auto parts store. Since the new ones are single lipped seals I figure more is better. The Screw you see on the right side below the shifter lever is the Poppett and spring that holds the PTO shift lever engaged
Post A Followup
: Re: Re: Super A Transmission
