Governor trouble on a 53 Super A?
Posted by SAm in NS on January 04, 2004 at 06:08:06 from (24.138.19.172):
I have a 53 Super A and it when it's cold out the engine tends to hunt sometimes. I went out plowing snow (there wasn't very much but I wanted to know if the blade I built works) last night and if you start of in any gear with the blade on the ground the engine bogs down and if you push in the clutch before it stalls then it will start to hunt. The only thing that will stop it hunting is dropping the throttle to idle until is stabilises and then increasing it again. I wasn't out very long but the governor was warm to the touch by the time I was done and the problem was better but still there. I'm thinking about rebuilding the governor and was wondering what parts I will need, what should be replaced or checked, and what adjustments I should make afterwards. Thanks, SAm in NS
Post A Followup
: Re: Governor trouble on a 53 Super A?
