Re: Governor trouble on a 53 Super A?
Posted by F-man on January 04, 2004 at 07:02:49 from (209.41.235.25):
In Reply to: Governor trouble on a 53 Super A? posted by SAm in NS on January 04, 2004 at 06:08:06:
Have you made any adjustments to it recently? The bolt in the top of the housing adjusts the speed settings and there is a nut on the bottom of housing that adjusts the governor spring. When the speed is adjusted, the control spring needs adjusted as well to eliminate the condition you are describing. If you don't have any luck there, Steel Wheel Ranch should be able to set you up with a re-build kit. www.steelwheelranch.com
Post A Followup
: Re: Re: Governor trouble on a 53 Super A?
