Re: Cylinder Sleeve Puller?
Posted by nate on January 05, 2004 at 03:20:00 from (12.32.223.199):
In Reply to: Cylinder Sleeve Puller? posted by C'ville Bill on January 04, 2004 at 18:12:40:
ive done a bunch 0f c 123 wet sleeve mototrs and been around or helped with a bunch of h sleeve jobs. we usualy use an old piston (this process usually ruins a piston and the rings for sure) put a ring in the top groove, bevel side down. compress the ring, and put the piston down into the sleeve, go to the bottom till the ring pops out.be careful as there isnt much room between the botom of the sleeve,and the bottom of the bore. we make a fake connecting rod about one and a half times the length of the real rod out of tubing. just weld a t on the top, then put a bottle jack under both sides of the t, and pump them up. the sleeve usually walks right up. usually have to use a new ring for each piston. i have only had one i couldnt get this way, and it was a newer job, with green loctite holding them in. a former ih mechanic came to the rescue,and said this was the second hardest sleeve pull he had ever done. the first hardest he said his puller base went down through the top of the block ruining it. when i did my 300, i took it to the loclal machine shop. i was putting thinner sleeves in, and didnt want to worry about breaking a new one.the machine shop only charged about 35 bucks to switch sleeves.i also had them put in new cam bearings, which i didnt have the tool to do. a 10-20 block may be a diiferent story. it might be a little much for the average machine shop. nate
Home
| Forums
Today's Featured Article -
Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
