Charging and Ampmeter on Cub Loboy
Posted by Red Raider on January 05, 2004 at 10:55:23 from (198.77.130.218):
I'm showing the 6 volt generator putting out 7.0-7-2 volts at the regulator, but the ampmeter is not registering a positive output. The motion is dead center with a very slight wobble at zero. It does show a discharge with the light switch turned to high and low. I would like to see the charge rate move into postive. Any troubleshooting ideas that I should try?
Post A Followup
: Re: Charging and Ampmeter on Cub Loboy
