Farmall Tractors Discussion Board
Re: H hyd pump
Posted by Mark on October 10, 1999 at 07:06:47 from (161.16.1.47):
In Reply to: H hyd pump posted by Rob on October 07, 1999 at 20:05:16:
Rob,
I have an H with a loader and don't know what I would do without it.
I would recomend that you invest your time and money into a live hyd system. The loaders powered from the original pump are unhandy. These pumps stop when you push in the clutch. The loader will work OK but as I said UNHANDY!
My H has live hyd. The unit is an M&W add on. This unit is driven off of the distributor drive gear. The distributor is relocated to the vertical position. The pump is where the distributor used to be.
I don't know if M&W still offers this conversion but maybe you can get a used one.
Good luck to you.
Later
Mark
Post a Followup
: Re: Re: H hyd pump
