Farmall Tractors Discussion Board
Re: 48 cub was running then just stop!
Posted by it smelled of rich mixture..? on October 10, 1999 at 10:24:24 from (207.115.63.18):
In Reply to: 48 cub was running then just stop! posted by Jim on October 09, 1999 at 22:38:32:
Jim: You stated it smelled of "rech" mixture? Why suspect ignition first? I would think mixture would be a first consideration.. Push off the choke? Maybe float is stuck? Turn off gas line and as carb runs dry it may CLEAR UP indication that the over rich mixture is finally leaning out as gas in carb is used up..That should confirm its gas related..? Why would "smelled rich" lead one to suspect ignition first? Anyway- good luck. harvey
Post a Followup
: Re: Re: 48 cub was running then just stop!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
