Farmall Tractors Discussion Board
Re: carbrator proublems??
Posted by John(TX) on October 10, 1999 at 16:13:26 from (216.198.61.90):
In Reply to: carbrator proublems?? posted by brandon on October 08, 1999 at 18:43:02:
Brandon,
Check your ignition coil or magneto. I had problems with an old 1965 Mustang where the original coil would get hot and drop voltage. It would idel fine, but when I put it in gear, it died. I guess changing the engine loading or fuel mixture was enough to make a weak spark not fire. I changed the coil and had no problems since. This also happened on my 1962 Comet.
Post a Followup
: Re: Re: carbrator proublems??
