Re: Re: Cylinder Sleeve Puller?
Posted by Pete L on January 08, 2004 at 09:41:33 from (198.36.89.4):
In Reply to: Re: Cylinder Sleeve Puller? posted by Dick on January 04, 2004 at 18:40:44:
Did most of what Dick did for pulling my F-20 sleeves. The critical thing is a stepped disk turned to a loose fit of the lower end of the sleeve, with the larger diameter less than the OD of the sleeve. A piece of 1 x 3 flat bar for a cross piece with a 1" hole drilled thru the center, 2 pieces of squared off 1 1/2" pipe for uprights, and 2 pieces of 1" plate to spread the load on top of the block. Pull the disk up to the bottom of the sleeve with a piece of 7/8" threaded rod and start cranking. My wet sleeves came out easily. Took more time to build the puller than to pull the sleeves.
Post A Followup
: Re: Re: Re: Cylinder Sleeve Puller?
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
