Re: Carb ? Am I missing the obvious still yet?
Posted by Bob on January 09, 2004 at 17:53:37 from (66.231.125.248):
In Reply to: Carb ? Am I missing the obvious still yet? posted by Jerry in MI on January 09, 2004 at 15:54:04:
Many carburetors have 2 float spec's, Float level and float drop. Often, there is a little tab that presses on the needle to close it. You typically make this setting with the carburetor top upside down, and measure from a specific point on the float to the machined area that seals against the gasket between the carb halves. The other adjustment is the "float drop". This setting controls how much the float will drop if the fuel bowl is empty, and helps prevent the float from sticking in the down position. This adjustment is made by holding the carburetor top in the normal operating postion, and measuring from the gasket sealing surface to a specific poiont on the float to see how much it drops when hanging free. The tab controlling this is normally 90 degrees from the on that operates the needle. Post back with the application you are working with and someone can give you the float level and float drop specifications for your particular carburetor.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
