Re: surging engine at rest in a 300 farmall
Posted by ChadS on January 09, 2004 at 21:23:14 from (66.228.96.213):
In Reply to: surging engine at rest in a 300 farmall posted by bill in orono,mn on January 09, 2004 at 18:37:08:
It could be the governor spring, worn governor weight pins. if it is extremly cold where you are from, may have some ice or very cold engine oil still in the governor, also in the governor shaft to the carb itself. You might check the idle adjustment as well. Check for any vacumm leaks on the carb/manifold flange. Hope this helps,, chad
Post A Followup
: Re: Re: surging engine at rest in a 300 farmall
