Re: Farmall shutters
Posted by Bob M on January 10, 2004 at 09:17:25 from (66.66.126.128):
In Reply to: Farmall shutters posted by waynekittler on January 10, 2004 at 07:16:17:
Like Dave says shutters were provided standard on distallate tractors to permit faster warmup. Shutters were an optional accessory on gas burners.
Shutters are nice if you operate lighly loaded in cold weather. Even with a working thermostat these motors will not warm up sufficiently unless airflow thru the radiator is partially blocked off.
Post A Followup
: Re: Re: Farmall shutters
