Farmall Tractors Discussion Board
Re: 6 Volt Or 12 Volt System
Posted by The Red on October 11, 1999 at 04:49:30 from (12.75.196.169):
In Reply to: 6 Volt Or 12 Volt System posted by MAD MAC on October 10, 1999 at 22:56:56:
Look at your wire going from the coil switch to the coil. If you see no ballast in the line, you can pretty much assume you still have a 6 volt system. The best bet would be to take the generator and voltage regulator to a gen. shop and have them test it. They will beable to tell you if its a 6 or 12 volt charging system.
Post a Followup
: Re: Re: 6 Volt Or 12 Volt System
