Re: Front pump not working on 806 need help
Posted by RB on January 12, 2004 at 06:50:35 from (64.136.27.226):
In Reply to: Front pump not working on 806 need help posted by Larry B. on January 12, 2004 at 05:47:53:
The MCV pump loosing prime is typical of IHC 706-1586. The cause is either a weak pump or a internal leak in the system. I've found that if you remove the flow divider completely, largest plug facing toward back of tractor (nut, spring and spool) then just crank the engine until oil squirts out, if you start the engine you will get
a gusher when it primes. If you didn't have any trouble before then it probably will be OK untill it sets without use again.
Post A Followup
: Re: Re: Front pump not working on 806 need help
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
